04-12-2021 07:45 PM - edited 01-06-2022 01:45 AM
I enter my email to get the reset password link but nothing gets sent it’s not in my inbox or junk
My Account
02-10-2022 04:53 PM
The bot is useless, it just redirects you right back to the password reset.
04-12-2021 09:13 PM
Are you entering the same e-mail address in both fields on the form?
04-12-2021 07:53 PM
@Thithanh wrote:I enter my email to get the reset password link but nothing gets sent it’s not in my inbox or junk
Hi @Thithanh to reset your password, contact the moderators using the links already provided above. Expect a response from the moderation in 2 -48 hours (much faster response these days). Keep an eye on the envelope icon on top right for a number to pop up... that would be the moderator's reply.
Also keep checking the email you use as username. They may send you a link there to verify this is your account.
Please keep us posted
RosieR
04-12-2021 07:53 PM
04-12-2021 07:51 PM
@Thithanh : Was it a quite long email address? Are you typing it exactly as the welcome email you would have got when you activated?
04-12-2021 07:49 PM
I’ve tried for the last 4 days
04-12-2021 07:48 PM
Maybe you typed it in incorrectly? Try it again.
If this continues not to work, you will need help from the Moderators.
To contact the Public Mobile Moderator_Team, there are two ways to reach them:
1 - Faster Method - Click the bubble comment circle on the bottom right hand side of your screen, or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower Method - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
