Resend porting text
Telya
Plz resend porting text thank you
Priority
Do you have access to sign into My Account and go into your My Profile Settings yet?
@Telya
Sent!!
Telya
Porting in plz send number to contact
@Telya
are you poring into PM or porting out of PM?
If porting out, you have to contact your new provider and ask them to re-trigger the porting process
if porting into PMThere is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed.  But the live support already closed, you have to call them tomorrow morning
