07-21-2023 10:45 PM
How can I redeem my rewards? I can’t seem to figure it out
07-21-2023 10:55 PM - edited 07-21-2023 11:00 PM
Login to the My Account site and click Rewards on the side, it will bring you to the rewards site. Then go to Catalogue and browse there and pick what you want to redeem. You can either use points to redeem for add-ons, usually cheaper than buying, or you can redeem 15 points for $15 bill credit
https://www.publicmobile.ca/en/ab/get-help/articles/redeeming-public-points
Let us know if you still have trouble finding the Rewards catalogue.
