Require help to set up Moto G 2nd Gen with 4G/LTE
Velvetsmack
Hi All,
Just started with Public Mobile today and I'm looking for some help on setting up LTE on tmy Moto G 2nd gen phone.
Firstly, I belive it can be done - however it only gives me the option of either 3G or 2G under Preferred network type.
What are the correct APN settings for this phone?
I have Android 6.0 currently
THanks for any help
VS
choco
Try another way: Settings -> About phone -> Regulatory information
Velvetsmack
Thanks - Looked at that.  There's no SKU number available under Hardware.
The best it shows is Version : P4
I'll also check to see if that holds any significance.
Edit: Found the model # under the cover - Yes its a XT1064 - Non-LTE
Thanks for all the help
choco
Actually, there is a Moto G 2nd Gen LTE, however I'm not sure whether that is designed for the US/CAN market (ie. whether it is compatible with the appropriate frequencies). To the OP: please go to Settings -> About phone -> Hardware information and post the SKU number listed on the phone (it should look like XT____).
McLaren
According to gsmarena 2nd gen Moto G does not support LTE
