2 weeks ago
- last edited
2 weeks ago
computergeek541
Hello, I have consistently been having issues with sending & receiving images via MMS over the past year. Specifically, MMS images are occasionally unable to be both sent and downloaded (downloading failed, tap to retry), with the most recent batch of failed images being sent on the 28th of May - prior to this date it had been weeks without encountering this bug. All other functions of the network appear to be functional, and I have already utilized a similar post from the community forums to verify that the the device's network settings are configured correctly. I'm currently using a Oneplus 12R (CPH2611), and can submit that these issues were not present prior to changing devices from a Oneplus 6t.
It would be helpful if Support would be able to assist me from their end.
2 weeks ago
@cgrey23 Have you checked the APN settings for that specific phone on the site Public Mobile recommends in their help page here?
https://apn-canada.gishan.net/en
Select Public Mobile and then Oneplus 12R. Although I note they don't have the SP.MB.COM in all caps which some have said is needed for Oneplus phones.
2 weeks ago
Have try doing a network reset on your phone?
2 weeks ago
You will need to open a ticket or private message PM and ask them if there anything that they can do. We are just customers like you here and it sounds like you have done all that you can without pm help. You can open a ticket using chat bot. Type in customers service agent or open ticket that should let you contact them. Or private message them below
