09-15-2022
09:06 AM
09-15-2022
09:25 AM
computergeek541
Is there a way I can contact someone at Public Mobile to request a credit? I purchased the data and talk/text add ons for the US but for some reason it didn’t work - I had no service. So, not only did I incur the cost of the add ons, but also roaming charges when I was trying to figure it out.
Thanks.
09-15-2022 04:59 PM
Another member already said that 8 hours ago
09-15-2022 10:34 AM
Yes where are you seeing these roaming charges? Spent out of your credit card? Deducted from your balance here? Autopay'ed from here?
You're the second one I've heard of this possibility.
09-15-2022 09:09 AM
hi I don't know how you could incur roaming charges since this is a prepaid service,none the less to contact a cs agent for refund or credit you need the help of a service rep
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or private message them here
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
09-15-2022 09:09 AM
@tasha_pm yes, you definitely can contact them for a credit. PM support are fair and they usually would try to work out something in such case. Please open ticket with PM Support using one of the 2 ways below:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
