01-16-2023 11:36 AM
- IMy husband left public mobile and wants to remove his credit card from automatic payment. He can no longer get into his Public Mobile account to do so as his SIM card has been deactivated.
Payment
01-16-2023 11:44 AM
IF he Ported out his number then his PM account is deleted. Nobody has access to it anymore...
If he did not ported out but let his account to go into suspense mode and he can still log in into it (meaning account still exists) ask agent to remove hs credit card info.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
01-16-2023 11:42 AM
Porting out closes the account. Just keep an eye out on the credit card used around the time when the renewal would have happened.
01-16-2023 11:39 AM
@mags7 @If the account is no longer active it will cancel completely 90 day after that point , otherwise contact support to have cc info removed right away
Getting help from agent
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get
Or get help right here in the community
- Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
01-16-2023 11:38 AM
@mags7 Did you port out the number to another provider?
If sim card is deactivated, there should not need to login to my Account to disable it
if you want, just message PM support to confirm
