Removing Voicemail
Burak
New in Town / Nouveau en Ville
Can i just remove my voicemail? i don’t want it. i want my phone to just keep ringing
1 REPLY 1
@Burak you cannot remove it but you can turn on extended absence.
  • Call voicemail and log in with your PIN.
  •  press 3 (manage greetings),
  • then 4 (manage extended absence greeting),
  • then 2 (record a new extended absence greeeting) and record a message that indicates to your caller you are not accepting messages.
  • Then press 4 to enable extended absence
  • Last, , press 5 to dissallow anyone to leave you a message.  Problem solved!
