Remove Mobile Klinik APP
C-137
I did not give permission to install it and want it removed, why is there no easy way to remove this spyware?
C-137
Read the reviews of the Mobile Klinik app or search Reddit as @fixin said, this spyware is installed without consent and no easy way to uninstall.
@C-137 I have PM app installed on multiple devices and none of them got other app installed with it
C-137
I only saw the Mobile Klinik app but now I'm going to look for other apps Telus installed without my permission.
@C-137
You should be able to uninstall it.  you sure that was the Mobile Klink app?  did you check the app screen on the settings, locate Mobile Klink app from there and try uninstalling it? or maybe send us a screenshot so we can understand
fixin
@C-137 - There is a similar thread on the TELUS reddit about this app being root installed by another app that cannot be uninstalled.
