07-20-2022 11:51 AM
Hi everyone,
I've been on the PM network for 1.5 years now. I had collected a couple rewards on the way but for whatever reason, they are no longer applicable to my account. I haven't changed plans (until today) and I'm not able to log on to the rewards page, irrespective of trying on different browsers. Any leads would be appreciated, thanks for your time!
Rewards
07-20-2022 01:52 PM
Thanks! I have actually enabled the pre-authorised payment but it doesn't show up. I'll raise a ticket for this.
07-20-2022 12:27 PM
Thanks @dust2dust . I missed it
Then I guess it is the system (again.. what's new.. )
@Mp26 open a ticket with PM CS agent, there are still couple days before your next renewal, they should be able to fix it before your due date
07-20-2022 12:19 PM
@hTideGnow- It shows as enabled in two of his images.
07-20-2022 12:18 PM
@Mp26 Set it up now if it has been disabled for whatever reason, your next payment is July 25, you still have time to enable it so you can save the $2 for next payment
07-20-2022 12:15 PM
HI @Mp26
on the same page, where you see the green box, you should see this if you have Pre-Authorized payment enabled:
It looks like it is not enabled
07-20-2022 12:08 PM - edited 07-20-2022 12:11 PM
Indeed. It says you have it set up but it's not showing the $2. I guess you'll have to contact the support people. Don't let them talk about points. Don't go to points.
@hTideGnow- I see the oops page that Mp26 shows.
07-20-2022 12:02 PM
Hi, thanks! The payment history doesn't show application of the rewards... I have pre-authorised payment right form the beginning.
07-20-2022 12:01 PM
Hi, thanks for your response! Here are the screenshots. The last renewal has only loyalty reward applied and not the pre-authorised payment.
As for the rewards page, it says 'under management' but that has been the case since early June for me. Saya under mainatainance
Rewards applied in the last cycle
07-20-2022 11:58 AM
@dust2dust wrote:I'm also not seeing the rewards page. Lots of changes around here the last few days.
Check your payment history records in the account for mentions of rewards.
HI@dust2dust , you meant you are not seeing the rewards page in My Account or not seeing anything when login to My Rewards?
07-20-2022 11:57 AM
07-20-2022 11:56 AM
HI@Mp26
did you login to My Rewards site and check:
https://www.publicmobile.ca/myrewards
please provide a screenshot so we can help
if you see rewards on My Rewards portal but not see PM give you the credit in the last renewal, please also post us screenshots
