Regarding the new plan
Marhoho
  • After I signed in my account, the it shows
the New plan should be active on 28th. But I didn’t see any change. By the way, the bottom one shown:
Aoubt Due Feb 26, 2024. What does it means??’Thank you!
what does
7 REPLIES 7
@Marhoho  I think only the $65 Canada/US plan has a 90 day option currently (in most provinces).
Marhoho
  • Thank you! Very clear explanation 。
@Marhoho
December 26/23 is the end of your 30 days cycle.
The 90 day plan will give you an additional $5 discount but is offered only in the higher data plans. It will be in the Subscription & Add-on section in your account if it is noted or just Google the Public Mobile plans.
Marhoho
  • Thank you! I guess my plan doesn’t show any choices. I’ve been charged every 30 day.
@Marhoho  Sometimes a plan will have a choice between 30 days and 90 days.  With the 90 day version you get 3 times the data at the beginning to last the whole 90 days.  You also pay for the whole 90 days up front.  Usually there is $5 or $10 dollars discount per 30 days on the 90 day plan.
Marhoho
thank you for your quick reply. I’m new for PM , so when means this plan will be expired on Deb 26, ,2024? By the way, what is different between 30 day plan and 90 day plan?
@Marhoho
This is normal on the day before your renewal date. If you have service just ignore it. There should also be the automatic Top-Up in your shopping cart to renew your plan.
You must be on a 90 day plan for the additional $5 credit/month but you are charge every 30 days. February 26/24 is when your 90 day plan expires.
