Refund
Ahmed126
Hi, i accidentally purchase 5gb data roaming internet package from my account. But i don't need it and can't use the internet also. How can i get the refund?
2 REPLIES 2
hi @Ahmed126
PM agent usually can reverse it for you and put the credit back into your account
if same, then submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
porcupine
Click on the pink chat link in the bottom right corner and follow the prompts for help with that
