Refund
Angela1088
How do I get a refund I bought a plan last night and its saying its not in service. How do I speak to a live agent
2 REPLIES 2
hi @Angela1088
if it is just a setup issue, PM support agent can review and help and fix it , so you might not need to cancel and refund
but either way, you will start by submitting a ticket with PM support agent,  you can submit  ticket by direct message:
slusagm
PM can help.  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
