Referred a freind
OakleyT
I referred a friend to PM. When do I start getting $1 savings for this?
@OakleyT   you only joined couple days ago, right?  If it is true, you will be on the new reward system
Login to My Reward site (https://www.publicmobile.ca/myrewards), you should see an increase of the number of Friend Referral within a week.  You will be earning 1 Point every cycle.  Together with your other points you earn, once you reach 15 points, you can redeem for $15 bill credit
Yummy
On next renewal. When did YOU join PM as it could be $ or points depending on join date.
dust2dust
Did the referring account start before late January? If so then you should see the new referral $1 immediately and then that would would reduce your next renewal cost. If you signed up after late January then you would be getting 1 point that does save you money until you convert it.
