02-19-2022 05:40 PM
I forgot to put referral code when i activated new sim card today
Rewards
10-24-2022 07:20 PM
02-19-2022 08:09 PM
unnecessary repetition
02-19-2022 05:59 PM
If you request nicely, the Customer Support Agents will add it for you after the fact.
Be sure to get all the digits from the person's referral code correct (i.e. the zero's and the oh's, and the one's and the i's) as those can frequently be difficult to discern.
Here's how to contact the Customer Support Agents.
To contact the CSA's, there are 2 methods:
- Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request). Click the result which states Click here to submit a ticket and follow the prompts, or,
- Send a private message to the Customer Support Agent by clicking here You’ll need to be logged into your Community account for the link to work.
02-19-2022 05:42 PM
don't worry get in touch with Customer Support Agent (publicmobile.ca)
will them Add.
