Referral
Soda-pop
  • How do you know if you received the 10 bucks for using a referral code
JRod
@Soda-pop
The $10 credit will be added to the account within 72 hours if the code was applied correctly. If for some reason after 72 hours it isn’t there you can contact support to have the code re-added.
kb_mv
@Soda-pop It will show up in your account as available funds. I believe it could take up to 72 hours if not quicker.
hi @Soda-pop you will see it in my account, shoeong up as Available Fund within 72 hours after activation
if not,  submit ticket with CS agent
