Referral code
sdudgeon741
I forgot to use my husbands referral code when I signed up!
Can I still add it?
I just signed up this morning...
7 REPLIES 7
sdudgeon741
well maybe they are
i just had to keep clicking the same thing over and over
sdudgeon741
options 2-4 are not there...
HI @sdudgeon741   Yes, PM Support likely will help if it was an honest mistake 🙂
Open a ticket with CS Agent using Chatbot.
click on the Bubble on the lower right or directly at : https://publicmobile.ca/chatbot.
Follow these these to get to ticket open page quicker:
  1. Type: My rewards are missing,
  2. click on "Refer A friend",
  3. click on "Yes, I'm the referred customer',
  4. click "Click here to submit a ticket" .
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
@sdudgeon741
You can contact the CS_Agent by clicking on the envelope icon and private message them and explain your issue.
sdudgeon741
Kool Thanks!!!
