Referral code
Jessi1
I forgot to enter the referral code I was provided by a friend. How do I fix this?
Triguy
Here’s when and how to contact the Moderator Team:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work
Staliger
@Jessi1 provide the code to moderators, and they will apply it to your account. Both you and your friend will get rewards. Please make sure that you use the correct code. Your friend will get SMS that the code was applied, and you will get 10$ within 72 hours. Welcome to PM!
kb_mv
@Jessi1 Contact a moderator by opening a ticket through Simon (? bottom right). Explain you forgot to enter a code and they will do it for you. Welcome to PM.
PS: If Simon gives you troubles try this: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
