Referral Code
01-18-2022
10:01 AM
01-18-2022
11:50 AM
computergeek541
01-19-2022 06:31 AM
This has been a frequent glitch of late of the referral code entered at activation not registering requiring the new customer to contact customer support to have it added. Your friend will see the $1 reward and the last 4 digits appear in their account immediately after it us added. You will see the $10 bonus referral credit within 72 hours but usually the next day.
Did you activate your account in 2021? Or 2022? If it was last year it will make a difference for your friend.
01-19-2022 12:00 AM
@Zyl wrote:@CBr all the rewards, the $1 monthly reward for your friend and the $10 reward for you only starts on the second billing, not the one that's taken immediately.
While it's true that these amounts don't get applied against the plan fees until a later time, the $1 reward for the referrers shows up in the account immedaitely. Also, the $10 for the customers referred shows up within 72 hours of activation. The customer does not need to wait until the next renewal to see that $10 credit.
01-18-2022 03:25 PM - edited 01-18-2022 03:28 PM
If by the second billing, you and/or your friend still don't see the rewards, you can contact the customer service of public mobile by sending them a private message by clicking on the "messages" icon and then the icon right beside "Inbox" and then typing "CS_Agent" in the "Send to" field to inquire further.
01-18-2022 12:15 PM
01-18-2022 10:46 AM
HI @CBr ,
You will be the one opening ticket for both your friend and yourself. Just one ticket from you would be fine.
To open ticket with PM, click on the Bubble on the lower right or directly at : https://publicmobile.ca/chatbot.
Follow these these to get to ticket open page quicker:
- Type: My rewards are missing,
- click on "Refer A friend",
- click on "Yes, I'm the referred customer',
- click "Click here to submit a ticket" .
- you will then direct to another page to open ticket.
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
01-18-2022 10:06 AM
@CBr , can you ask your friend to check their rewards tab in the self serve account and see if there is a reference to a successful referral being made? If not, maybe something glitched. Click on the chat symbol on the lower right corner and initiate a support ticket. The CSAs will look into the matter and make the appropriate corrections.
