Referal Credit
fisnaris
Why was my referal code not accepted when my friend signed up ?
Yup, until the  your friend code is sorted out , PM Support is your friend's best friend, ask them to Chat Bot Simon to get a ticket or send a private message to CS_Agent
Use the steps provided above
walker1
@fisnaris   After your friend entered your code during the activation process, they may not have applied it and not gotten the green check mark.  No problem though, they can get that fixed.
Your friend will have to have a PM customer service rep fix it for them.
They can reach them by using the Chat Bot Simon to get a ticket or send a private message to CS_Agent
@fisnaris   you friend could have copied or entered wrong
But no worry, ask your friend to open a SINGLE ticket with PM Support for both of you .  They will validate and add the friend referral credit back
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
