10-02-2022 03:34 PM
When I referred a friend last week, we forgot to put in the “Refer-a-friend code”. How do I do that now, after he has already activated his card?
Rewards
12-26-2022 10:29 PM
@IanJPerry Perfect if you are the newly joined customers.
But before you open the ticket, make sure you have joined for over 72 hours, then check your My Account to see if you see a $10 showing up in Available Fund. If it is there, then you got the referral bonus already
But if you don't see the $10, then open ticket with PM Support as my post mentioned earlier
12-26-2022 10:09 PM
A friend referred me
12-26-2022 08:13 PM
@IanJPerry are you the one referred your friend?
if so, ask your friend to open ticket with PM Support. Follow the steps to open ticket in the post above
12-26-2022 08:08 PM
I'm looking for an answer to this as well.
10-02-2022 07:08 PM
Agent can do that for your friend.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
10-02-2022 03:40 PM
@DianaW have your friend to open ticket with PM support, they can likely able to add it back
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
