Refer-a-friend code
EJHayden
My friend tried to use my refer-a-friend code and was told they need the phone number as well, which she didn’t have. Can she use it retroactively?
Yummy
Then she can apply your referral code WHILE opening an account or if she already opened it, ask agent to add it manually.
HALIMACS
@EJHayden
She can.
  1. Use the ticketing system for a faster response time. Click here to create a support ticket, or
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
dust2dust
There's no place to put in a phone number. Where did they hear that?
Yes, she can ask support to add it for her.
