Redeeming Points
Sonnar50
When I reached 95% of data usage I redeemed 20 points to get 3GB of extra data. My account now shows the additional data but once I reached 100% usage of my regular plan amount, I was cutoff. What gives? Will I lose those 3 unused gigabytes at plan renewal. How is this not “bush league”?
Techfish
Does your phone have a data limit set in Settings?
@Sonnar50
It will use up the remaining 5% left from your plan then it will start to eat away from your 3gb Add-on. Depending when n your renewal date. It will continue to use up the Add-on until it is used up or expire after 30 days. On your renewal date, it will top up your plan data.
hi @Sonnar50 make sure your phone does not have a data limit setup
Reboot phone and try again
if same, ask PM support to check and help
submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
