Recorded error message hb1 or 8b1
Meyerw
Received the following recorded message when calling an operational local phone number: 8b1 or hb1 Your call cannot be completed as dialed. Please check the number and try again?
The number called is operational?
vlgj327
but do you have the same message calling all numbers or just one?
Try again, it should work
If not, click the envelope icon on top right. If you don't see the envelope, click you avatar in top right to bring up the menu and select Messages
As they said they sent you a message.  So when you click on the link, you should see their message. You need to provide the details to the agent.
Meyerw
Hit the link & nothing happened?
CS_Agent
Customer Support Agent
Hello there.
I sent you a private message.
You can view and reply to it by accessing this link:
