Reception bars
12-13-2024
02:47 PM
12-13-2024
02:56 PM
computergeek541
Why do my bars in the top right corner have spaces at the bottom like exclamation marks? I have not noticed this before. Thanks
Phones
12-13-2024 08:41 PM
You nailed it ! Thanks!
12-13-2024 05:55 PM
I found this in the US, roaming on AT&T. It did not affect performance.
12-13-2024 03:41 PM
@Kdhd are you referring to iPhone specifically? I think it means you have 2 SIM cards configured...
12-13-2024 03:09 PM
self solution removed
12-13-2024 03:01 PM
I had no data up until today and the bars were split but they still look like that. So maybe it’s a glitch. I’ll try turning my phone on and off once more. Thanks all
12-13-2024 02:56 PM - edited 12-13-2024 02:58 PM
@Kdhd wrote:Why do my bars in the top right corner have spaces at the bottom like exclamation marks? I have not noticed this before. Thanks
On many devices, an exclamation mark means that you not have a data connection or that mobile data is turned off in your phone's settings.
12-13-2024 02:52 PM
@Kdhd I would say if your services are still working fine then it's likely nothing to worry about although I haven't seen that before. Have you tried restarting your phone to see if it returns to normal?
