05-09-2018 04:51 PM - edited 01-05-2022 04:45 AM
Ever since that really massive storm that rolled through with high winds, I've noticed that PM coverage has been dropping out quite a bit for West Island of Montreal.
I've never had any coverage network issues before the storm, Since then, my phone is frequently off the network at home.
05-10-2018 09:48 AM
Took a drive last night and I got coverage again. But I no longer get coverage at my house like I used to. I hope this gets resolved soon as I prepaid to the middle of July. If I no longer have the coverage I had before, then that's not going to be acceptable for me. I will have no choice but to switch back to another carrier.
If I don't pay my bill, I get my service cut off. And when I pay my bill far in advance, I lose my network coverage? Public Mobile should be issuing credits for customers that lose network coverage for their towns.
05-09-2018 06:46 PM
Sounds like Tellus maybe having problems?
https://istheservicedowncanada.com/status/telus
05-09-2018 05:55 PM
My wife is on Rogers and she has no problems. It also seems like it doesn't matter what network type I select. Not sure I'm doing it right, but I select global or LTE, and I just get no coverage. I see it flash with bars sometimes, then it drops.
05-09-2018 05:10 PM
Check with others that use Telus/Koodo/Bell/Virgin if they are experiencing similar issues with their phones.
05-09-2018 05:04 PM
@jlangdale wrote:Ever since that really massive storm that rolled through with high winds, I've noticed that PM coverage has been dropping out quite a bit for West Island of Montreal.
If you are using LTE, try 3G for now. It may be a better signal.
