08-14-2018 04:26 PM - edited 01-05-2022 12:30 AM
After I registered my new Public Mobile Sim card, I decided to try porting my currently active Speak-Out number. It asked for the old account number that I could not find even after digging through many other community posts talking about it so I just put the old phone number instead(One person said that it worked for them). But this morning I recieved a text stating to fill out a Sim & Activation form under the "Contact us" tab on the Public Mobile website, after thirty minutes of searching I could not find the mentioned form. If anyone has advice for how to solve this, it would be greatly appreciated. Thanks.
02-13-2020 04:20 PM
Happy to help! ![]()
For Speakout you will need the IMEI for the port and to contact the moderators to modify the information.
Submit a ticket via the 24/7 virtual assistance SIMon to get this looked at
Note that you will need to create and/or sign in to the Community for the below link to work.
SUBMIT A TICKET - https://www.publicmobile.ca/en/bc/get-help
08-14-2018 11:10 PM
I have the same issue porting Petro Canada mobility number over to PM. For PetroCan the account number is the phone number. I followed the advice here to contact the moderator team with all the necessary info and the porting is fixed within 24 hours.
08-14-2018 06:44 PM
my port was in June, 2018
@happycamper wrote:
@wetcoaster wrote:
@happycamper wrote:For anyone porting from Speakout...there are no account numbers...
You only need your phone number AND your pin number .....it should work fine if you have these....at least that's what worked for me
It seems to be a bit YMMV... Granted, not up-to-date information (April 2017), but I was advised by the SpeakOut CSR that I finally reached that they need the IMEI and PIN, which ended up working (SpeakOut also put a 48 hours hold on my account, preventing porting out, after the phone number & PIN attempt failed.)
I had both the pin and IMEI ready to give the CSR at Walmart when I ported but she just did the PIN and it worked
08-14-2018 06:43 PM
08-14-2018 06:16 PM - edited 08-14-2018 06:17 PM
08-14-2018 05:09 PM
You only need your phone number AND your pin number .....it should work fine if you have these....at least that's what worked for me![]()
08-14-2018 04:39 PM
@Spo0key further to @computergeek541's reply, here's the details to contact the moderator team about a porting failure:
How can you get help with your account, activation, or service?
In your message please include:
If you have a Porting issue, please also include:
Don't know your pin?--provide any 3 of the following:
How long until they reply?:
Additional Useful Information:
08-14-2018 04:31 PM
@Spo0key wrote:After I registered my new Public Mobile Sim card, I decided to try porting my currently active Speak-Out number. It asked for the old account number that I could not find even after digging through many other community posts talking about it so I just put the old phone number instead(One person said that it worked for them). But this morning I recieved a text stating to fill out a Sim & Activation form under the "Contact us" tab on the Public Mobile website, after thirty minutes of searching I could not find the mentioned form. If anyone has advice for how to solve this, it would be greatly appreciated. Thanks.
There's no such form that you can use to contact Public Mobile customer service. All customer service requests must be done by sending a private message to Moderator_Team.
That text message is sent whenever a number portability request has been rejected by the other carrier or has otherwise failed for whatever reason.
As you typed in your phone number as account number, the request was likely refused due to mismatching Speakout Wireless account information. You will need to provided at least one of your Speakout account number, account PIN, or IMEI number and then provide that to Public Mobile so that the moderators can retry getting your number transfered.
