11-30-2016 01:24 PM - edited 01-04-2022 01:20 PM
Hello,
Just received my SIM in the mail (Ordered on the 15th). Which Mod should I PM to get the 4GB 40 dollar plan?
Thanks!
Joining Public
11-30-2016 01:42 PM
This is the procedure to follow to get the promo:
DO NOT TRANSFER your old number to PM when activating for the first time. Make sure everything is working before you do that. Suggest you read:
Also some "Do nots” for port-ins:
- if coming from Koodo do not use the same email address for Koodo and Public Mobile
- do not request the port-in during activation; take a temporary number, log out, confirm all services are active, log back into your account and select Transfer Number under Change Phone Number
- do not use any identifier except your account number EXACTLY as shown on your bill; it is the best item for any port-in request
- do not make any errors in the Authourized User; this must be EXACTLY as it appears on your bill
- do not use your number as the Alternate Number; use someone else's
- do not forget to click "I am authourized ...." BEFORE you entering your number (courtesy imm1304)
- do not cancel your account; that will happen automatically
11-30-2016 01:35 PM
@ultimatekarnage Any mod will do, they share an inbox bsically.
