11-19-2020 03:47 PM - edited 01-05-2022 04:10 PM
11-19-2020 03:52 PM
@tofhossain wrote:want to transfer koodo number to public
@tofhossain If its Koodo prepaid then you'll need to ask moderators for assistance after you've activated your SIM/Account. You can take a temporary PM number whilst moderators facilitate the port. If it's Koodo postpaid then you can port in the number at activation.
Contacting moderators can be done either via chatbot bottom right of screen and type in Port Request or click the envelope icon top right and private message Moderator_Team with Port Request in the heading.
11-19-2020 03:50 PM - last edited on 02-04-2021 08:15 PM by Ioana_R
Here is some additional info to help you out:
Porting Your Number Into Public Mobile
If you are porting your number into Public Mobile, for additional security, your previous service provider may also send an SMS text to validate the transfer. Follow the instructions in the message within 90 minutes to approve the number transfer.If you have missed the 90 minute window to respond, we will send you an SMS with instructions on how to re-initiate the transfer by calling our Porting team.The SMS will read as follows:Public Mobile Msg: The request to move your phone number to Public Mobile has timed out. Don't worry, you can easily re-initiate the transfer. Please call our Porting Team at**to authorize your number transfer
Tips:
11-19-2020 03:50 PM
Get a public mobile SIM card and join public mobile with a new phone number. Once it’s up and running contact a public mobile moderator and have them port your number over from Koodo.
11-19-2020 03:49 PM
@tofhossain Please use the directions from before. Go to https://publicmobile.ca.ada.support/chat. Typb "port request".
