09-12-2021 10:35 AM - edited 01-06-2022 03:21 AM
I did those things suggested and I cannot access data. I live in Lethbridge, Alberta.
09-20-2021 10:36 AM
@aprilmatisz wrote:My data was used up. This was strange to me, as I should have had more, but ccome the new billing period everything worked fine.
You can always check My Account for exact data used. If you are keeping data on all the time on your phone, system and 3rd party apps can easily use big chunk of data due to constant web checks: emails, weather, updates, whatnot.
09-20-2021 10:35 AM - edited 09-20-2021 10:50 AM
What plan you have?
Allotted data will reset at every renewal.
Apps could use way more data than you expect. Malware even more so.
Check if you can restrict background use of data by apps on your phone.
And make a habit of only turning data on when you need it.
09-20-2021 10:33 AM
Good to know that everything cleared up.
Sometimes your data can be used up by one of your apps, phone updates, etc. You could keep track with your phone data tracker, or 3rd party app.
https://www.publicmobile.ca/en/bc/get-help/articles/managing-your-data-usage
In the future, if you need data right away, you can purchase a 1 GB data add on for $15. Or change plans immediately or ask Customer service agent (CSA) to renew same plan earlier. However, PM does not pro-rate plans.
09-20-2021 10:29 AM
09-12-2021 12:14 PM
do one thing Make sure your phone is off before removing your SIM card,
and take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
09-12-2021 11:51 AM
I am guessing this topic has been chopped out of another topic as the subject begins with re:
So the original details have been left behind somewhere.
AE_Collector
09-12-2021 10:53 AM
More details would be helpful. Does your talk and text work?
Did data work before?
Which plan?
As noted above, first thing to check is whether you ran out of data. Check your self service account. Under Data and add on section. If you don't see a data counter/tracker, that means that you ran out of data.
P.S. I started your own thead/topic
09-12-2021 10:42 AM
hi
if data not working check your account online and see if you have any data left.
sometimes all your data can be used without you knowing . it has happened to me a few times where in the middle of the a night all my data was consumed no idea how
have never gotten an explanation.
