07-17-2020 11:36 AM - edited 01-05-2022 12:08 PM
I'm not sure if I should start a whole new thread or not for this but what does it mean to add tags to a post? I don't understand? Could someone explain this to me? Thank you in advance.
08-15-2020 06:18 AM
I had forgotten how tagging a post worked....its a lot easier using the search bar to find certain posts....now if i could only remember to do it the next time i have to search for a certain post.
07-17-2020 03:09 PM
Oh that makes sense. Thank you that's handy to know as I get to know public mobile and how everything works.
07-17-2020 01:10 PM
@treefrog wrote:I'm not sure if I should start a whole new thread or not for this but what does it mean to add tags to a post? I don't understand? Could someone explain this to me? Thank you in advance.
@treefrog, you can add a tag to any post you like and it helps when you use that word or phrase in the search bar. PMGUIDE has been a popular one. If there is a post that say helps you with Data on your iPhone (not saying you have an iPhone) you can tag that post as iPhone Data and if someone has a similar problem as you did you can search it up and reference that post for the new customer.
07-17-2020 01:04 PM
This is as good a thread as any.
Tags make things a little more searchable. You can tag any post, yours or not.
