03-04-2020 01:30 PM - edited 01-05-2022 09:46 AM
03-05-2020 04:08 PM
Oops, a hard reset: turn the phone completely off, wait a couple minutes and turn it back on.
03-05-2020 04:06 PM
I had the same problem. It may have been caused by a phone update. I did a hard reset and my calls started ringing correctly. Good luck!
03-04-2020 04:07 PM
@kaoka wrote:All calls going to answer machine. how to make it right?
Do outgoing calls work? Did you ask to have a number transfered in from another carrier?
