Re: US Add-ons not working, needs a refund
04-03-2018 04:06 PM - edited 01-04-2022 03:51 PM
04-03-2018 05:38 PM
You have only added the add-on for 500 mb of USA data and not any add-on for calling or texting while in the USA. You are getting the service you exactly paid for. If you go back to you account and add the add-on for USA calling and texting you will then be able to call and text while in the USA.
04-03-2018 05:16 PM
@asangaai, did you try manually connected to the roaming partner network. It is possible the phone was unable to navigate this automatically and required manual intervention.
04-03-2018 04:07 PM - edited 04-03-2018 04:10 PM
@asangaai, Any sort of refund request would need to go through the moderator team.
Click here to send the moderator team a private message.
You can find information regarding the moderator team by following this link.
EDIT: After taking a second look, it looks like you have a long distance plan to call Canada & US (from Canada) and a US DATA roaming plan, but no US call/text roaming plan.
