04-03-2018 07:17 PM - edited 01-04-2022 03:51 PM
I have the same problem with my Iphone 6s plus.
I was able to share my connection with Telus. Since I switched with PM I am not able to share my connection. The computer will connect to the phone... but I do not have access to the internet.
Did anyone find a solution?
Thank you!
04-03-2018 07:31 PM
Hey everyone!
I solved my issue with this link: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-up-Data-APN-on-your-phone/ta-p...
basically it was the name of the Cellular-Roaming-Cellular Data-APN
APN= sp.mb.com
It seams to be working fine... 🙂
Cheers
04-03-2018 07:25 PM
This is not a restriction by Public Mobile. If tethering malfunctions it is a phone setting. iPhones have no manual way to adjust these so try:
a) turning off wifi
b) rebooting
c) reseting network settings (you will need to reenter wifi passwords)
Are you able to surf the 'net with your phone?
