10-20-2025 05:57 PM
Hi,
I have a similar issue. Waiting to port out of PM. CS Agents keep asking to authenticate and I've provided all info.
How can I contact a supervisor?
Thanks in advance
10-20-2025 06:30 PM
You are in a queue to be served by the next person available.
You just have to keep watching your inbox for their response.
10-20-2025 06:29 PM
unfortunately, you'll have to work with Customer Support...there are no "supervisors". Use this link and request that your issue be escalated to a senior support person....
How to check for a response:
Try restarting your cell periodically to see if it's right.
10-20-2025 06:21 PM
Is there a list of supervisors that I could try contacting? Several of my 2FA rely on this number and I need to be responsive at work etc.
10-20-2025 06:04 PM
Thanks!
The first 2 ports failed because PM reported some technical issues. And now I don't having incoming calls or text on my PM number.
I've also provided all requested info to CS_Agent but no luck.
And I've asked to escalate.
Waiting..
10-20-2025 06:01 PM
is your PM account still active and able to receive text?
did you ask your new carrier to re-request the port?
For PM, you just need to ask them to escalate and help further, there is no other way than work with them via private message
