Re: Replacing the $35 1.5GB Plan with a $30 2GB Plan
Sampatterson
I need help!!
my Public phone plan won’t work I’m seriously so frustrated I bought credit it wouldn’t work I had to drive around Vancouver trying to find my way out with no map do you know how Stressful that is
12 REPLIES 12
@Sampatterson since you're able to use wifi at the moment, you can download offline maps of Vancouver in Google maps. at least you will be able to get around without data
@Sampatterson wrote:
So confused cause I’ve been with Lublin for
months and never have this problem .
so let’s say I’ve only been buying data add ons... how do you pay for my plan ?
im so
confused !! My account shows I have money but my phone won’t allow 3G, phone calls or texts ARGHHHHHG
Maybe you're thinking of pay as you go services. This is a pre-paid 30 day term plan. Come renewal time, the Available Funds needs to be sufficient to cover the plan cost.
Sampatterson
im so
Sampatterson
Sure I’ll do that!
@Sampatterson did you use the $80 to buy data add-ons? If you did , you would have still had to pay your plan on the 10th. Consider moving up temporarily to the $50 plan you get 3 gigs extra for $10 per 30 day cycle. Place $50 into your account and go to to switch plans page and choose the $50 plan and the switch immediately option. Here's an article on switching plans
https://www.publicmobile.ca/en/on/get-help/articles/change-your-plan
And heres where and how to do it.
 Stay safe.
@Sampatterson
What plan are you on ? Do you want to be on the $50/8.5gb plan til you get wifi back? Its cheaper to renew early or change plans then buying add ons.
I actually went to Walmart twice this month and bought two $40 top ups and utilized them all on my account cause I had no wifi all month basically.
but throughout the month it kept saying my service will expire on August 10 which was yesterday. But I bought over $80 of public mobile credits this month and now my service has been completely deactivated I’ve tried calling 611 and it tells me this this is so unfair I really wish this company had a person to talk to
How do you mean "utilized them all"? Did you buy add-ons with the money?
If it just sat there waiting for the renewal then your renewal certainly should have happened without a hitch. But if you otherwise spent it then there wasn't enough to renew the actual 30 day plan.
Sampatterson
Sampatterson
RossN
I need help!!
@Sampatterson hi if you have the funds in your account is there a reactivate button in your account also try by dialing *611 to pay
@Sampatterson
Did you purchase a voucher? You can add it by dialing 611. Press 1 then 1 again then enter the 12 digit pin #.
darlicious
@Sampatterson
Yes i do i ride a bike in vancouver.....now did your plan renew last night? What plan? Do you have any services?
