Re:- Public sends account access code to an old number
Shire-Reeve
A Public mobile client since 2021, I changed my number and updated the online profile in August. When trying to access my account online,  Public states it sends the 6 digit security code to my old number. That number is no longer in "profile".      Solutions?
Further, numerous attempts to contact an agent with a ticket agent result in a "404" error.
Thanks for any assistance.
9 REPLIES 9
hi @G_Cristian because when  you check mar Trust device first , you clicked Didnt receive code and Send email, then screen will go back to the enter 2FA code screen with Trust Device unchecked.  In other words, the earlier clicked in Trusted was wasted
I tried and confirmed that experience
G_Cristian
@hTideGnow Thanks for the follow-up. I have retested and can confirm it works with either  3 ways:
1. Click Trusted Device before 'Didn't get code'
2. Click Trusted Device after you clicked send email (as you said)
3. Do not click Trusted Device before or after (I suppose this should work for repeated logins with only user/pass but no OTP - did not test that)
hi @G_Cristian
you need to click Trusted device After you clicked send email
G_Cristian
You mean this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
For me, it does not work, unless you are already logged in, try in Chrome Incognito or something.
@Shire-Reeve This is what works for me if you can't get the OTP to your phone but email address is valid:
https://selfserve.publicmobile.ca
In this exact sequence:
1. Click on 'This is a trusted device'
2. Click on 'Didn't get code?'
Get options Text, Email, Voice' > Email
Enter OTP from Email, should be able to log in
@Shire-Reeve   The link you were given is to private message customer service and by-pass the usual ticketing system which is broken.
Shire-Reeve
Thanks. I can't get a ticket - repeated 404 error.
Shire-Reeve
Thanks,
Unfortunately attempts to submit a ticket result in repeated 404 errors.
I can get in by email but need desktop access. My profile was updated in August and the old number deleted.
hi @Shire-Reeve
contact cs agent by direct message, please submit a ticket with CS Agent here:
For the phone number 2FA,  click Didnt receive code and check if Send email is an option.  Use that and go to Profile page, Manage EverSafe id and change phone number there
But of course, if you  cannot even login, submit ticket
@Shire-Reeve  Submit ticket with support to help
send a  private message   To CS_Agents
