Re: Porting from PC Mobile
ivana
I'm also trying to get assistance with transfering PC Mobile number to Public Mobile.
Can someone help me? @CS_Agent
Please and thanks,
ivana
Thanks.
MoraMan
Please and thanks,
@ivana what is the issue you are having? I ported to PM recently. Was very straight forward.
Luddite
@ivana Try your old SIM. If it works just keep using it until the PM SIM is functional. Do not close your old account; that will happen automatically. Or if you have another phone, use your old SIM in it and carry on with two phones
If your port-in of a cell number has stalled more than 3 hours you will need moderator assistance. If so, send  a private message to the moderator team with your account PIN and an explanation. Include the following info:
  • PM SIM card number
  • PC Mobile account number, exactly as shown on your bill
  • PC Mobile phone number
  • the account holder's name, exactly as shown on your bill
  • an Alternate Phone Number; someone else’s, not your own
Hi @ivana, what seems to be the issue with porting from PC Mobile.  Have you already activated your SIM and received a number from Public Mobile, or were you planning on doing the activation and port all at once.
The following knowledge bas article might be of assistance: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-to-Get-Started-With-Public-Mobile/...
Otherwise, please give us more details, so that we can help you better.
On a side note, it is always better to post a new question in a new topic.  That way you get the attention you deserve.  Otherwise, you question could go unnoticed.
