07-21-2023 09:20 PM
I’m stuck in number port limbo - I’ve been trying for 5 hours with support. Can you share the # with me as well?
07-21-2023 10:57 PM
@NatMclarty um. .there should be an email with the QR code. Check if you also receive the "Activation Summary email"
https://productioncommunity.publicmobile.ca/t5/Get-Support/Important-Update-eSIM-QR-Code-Now-Include...
If you cannot find it, you have to message support and ask them to resend you the code:
07-21-2023 10:35 PM
You mean this welcome email with no QR 😭😭😭😭😭😭😭😭😭😭😭😭😭😭😭
07-21-2023 10:22 PM
oh, you are using esim.. physical sim would work but you need support to change it for you on the system
since you are not going to get a physical sim tonight, let see if we can make the eSIM work tonight
There is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone
Once you installed the eSIM profile, (or If you got passed that step), try to reboot your phone once.
If it still does not connect and if you have any active sim on the phone , disable them (eSIM/Physica sim) or remove the physical sim. Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetoosh connections, but you just need to add them back after)
07-21-2023 10:20 PM
I’m thinking of hitting up my local mall. If I purchase an sim tomorrow can I abandon this e-sim process and just use the physical-Sim with my ported #? Or am I committed to this limbo and must get out via support? Or is something else entirely different required?
07-21-2023 09:26 PM
@NatMclarty wrote:I’m stuck in number port limbo - I’ve been trying for 5 hours with support. Can you share the # with me as well?
sent via private message. Plese check your Community inbox
