Re: Picture and Group Messaging End Date | Feb 14
LPPM
We cant send any pictures to anyone
13 REPLIES 13
LPPM
I also updated Lineage to the newest 21 TD
LPPM
CS changed my plan as requested this cell works properly now.
It may have been a bad activation on my part, I had to use an old cell G7 with google to activate my plan with the Public Mobile app then switch back to A33
We should not be required to have a Google or iPhone just to activate, I did not see any email option
When Liberty Phone and sim is available in Canada I will be giving it a try too
https://puri.sm/products/liberty-phone/
But the other Linux cell which is completely different also Now works, No idea why
Al_Harisi
Try changing all instances of APN names from sp.mb.com to SP.MB.COM (all UPPER CASE). This actually finally solved the issue for me, as mentioned here
LPPM
I used my 2 different sim cards, 2 phone numbers,  in a know working Normal Android Google Factory only cell they both still does not send pictures
So my only conclusion is,... it is a Public Mobile Issue
LPPM
I think I answered my own question
I will see if the LinageOS is the problem After CS changes my plan
I will put back to Samsung factory temporarily
Thanks
LPPM
Tried Network Reset
Restart a few times checked message settings tried different ones
I am waiting to for CS to change my plan before I make any OS changes
installed LineageOS 20 from Andy Yan
Had no issues until now with new Subscription plan from public
HI @LPPM
A33 is not a linux phone, unless you flash a new OS
you can try Reset All networks and see if it works
LPPM
Samsung A33M
LPPM
all cells 2022 or newer Samsung
HI @LPPM
what model is that phone?
LPPM
sms or MMS
LPPM
Is this why None of our Linux Cell phones work now ??
