Re: Network locked SIM card inserted
afrose
Acekiller
in case you don't know, all unlocks are free now.
ky01
I agree with @KMG, if you're getting that message, your phone might be locked to your old carrier. You should request for an unlock code from your old carrier to have your phone unlocked, prior to being able to use Public Mobile 🙂
KMG
If you insert the SIM card and receive a network lock message, that probably means that your phone is locked and needs to be unlocked before it can be used with Public Mobile.
ShawnC13
@afrose, do you have a question we can help with?
