04-10-2021 12:31 AM - edited 01-06-2022 01:43 AM
Hey! I have a Jethro model SC213....
I was on a Rogers plan for a while and was hoping to set my grandma up with this phone. Now I'm hoping to use Public mobile.. I seem to have troubles getting things to work out!
Not sure what my problem is exactly!
If you know of anything I'd love to hear it. Thanks
Phones
04-11-2021 01:05 PM - edited 04-11-2021 01:10 PM
Dang, Jethro is ACTUALLY a brand of cell phone..... never heard of 'em! 😮 Makes me wonder if they have 3 other models..... Granny, Jed, & Ellie May! 😉 🤣
Looking at them, it APPEARS that the "SC" in the name stands for "Senior Cell"..... 🤔
That, and after doing a little bit of looking, apparently the Ver.2 of this phone is 3G, and compatible with most/all Canadian carriers.
04-10-2021 11:19 PM
@brovogel wrote:Hi, So I guess perhaps my version of Jethro is not compatible with PM sim cards.
I have a SC213 model!I'm not sure what makes a phone not compatible. If you understand do you want to explain it to me?
thanks
That phone is almost useless in Canada. It can only be used on the Rogers network and Rogers is turning off 2g soon. As above, you need 3g, but you not any 3g. You need 3g 850 and 3g 1900.
04-10-2021 11:08 PM
@brovogel SC213 is a 2G phone. you need at least a 3G phone to use on PM
04-10-2021 11:03 PM
thanks
04-10-2021 06:17 PM
you can request the PIN Unlock Key (PUK) from the Mod if it is locked out.
04-10-2021 06:10 PM
Hi again,
So I took out the sim again and waited 5 min and now it's gone to the sim pin code screen.
I tried 7985 which I thought was my pin for this sim card...
I have 2 tires left.
I'm worried I'll do something I shouldn't so I'm gonna wait and see if you have any feed back.
THanks!
04-10-2021 05:33 PM
@brovogel wrote:Thanks RosieR
I hope I can put the PUK in and then see what happens.
Thanks for your help. I just submitted a ticket.
@brovogel you're welcome. There are about 4-5 moderators present right now so I hope you get a reply soon. Keep an eye on the envelope icon to top right for a number to pop up... that would be the moderator's reply.
Cheers
RosieR
04-10-2021 05:14 PM
Thanks RosieR
04-10-2021 04:53 PM - edited 04-19-2021 02:16 PM
@brovogel wrote:I got myself stuck in a PUK code loop. I somehow have to figure out what my PUK code is.
However Rogers never locked my phone and since I don't have an account with them anymore then they can't get my old PUK.
when I have the Public mobile sim card in the phone it is in the PUK input mode when I don't have the sim card in it is the regular opening screen.... any suggestions or support is appreciated. Thanks 🙂
Hi @brovogel
EDITED as there is already solution accepted.
Aloha
RosieR
04-10-2021 04:46 PM
![](/skins/images/DCE4DBC5FB75F667235A257F9030739A/responsive_peak/images/icon_anonymous_profile.png)
04-10-2021 12:55 AM - edited 04-10-2021 12:56 AM
@brovogel : If you manually scan for networks then if you have 3G or WCDMA or UMTS set then it should find Public Mobile.
The phone should work fine. It's likely just settings.
04-10-2021 12:41 AM
ohhh darn I think there is a problem. Its finding the old rogers thing that I used to have!
Yikes how does this happen! I"m not sure how to delete it..
04-10-2021 12:41 AM
@brovogel : So what happens when you touch that Automatic?
04-10-2021 12:39 AM
hummm thanks well I am in network settings and doesn't really look like I have options to change things like you suggested. it's just "Automoatic"
Anyhow appreciate your message
04-10-2021 12:34 AM - edited 04-10-2021 12:35 AM
@brovogel : Check to see that the networks are set to 3G or WCDMA or UMTS not just GSM.
Don't forget to use a referral code to get a $10 credit.
![](/skins/images/34AB3B0FE78BBE11DBF186F131BC3766/responsive_peak/images/icon_anonymous_message.png)
