Re: Iphone APN setting not showing
01-06-2018 06:22 PM - edited 01-04-2022 03:15 PM
Been there, done all that and more, checked with IT peoples at work, they all agree it’s a public mobile issue not the phones. It seems there IS NO FIX to this APN screw up, I’ll just let the 90 days I paid for go by and then get a provider that can help via more personal like. At least I can talk and text until then. I will say however it’s too bad, Public Mobile does have the best rates I’ve seen in all my searching.
Joining Public
01-07-2018 02:59 PM
I have tried on iPhone 5s and se, and as I said been there, done all that and still no data thank you for the suggestion anyway
01-07-2018 11:13 AM
@Algaede your thread was moved so not sure what the been there done that refers to. as mentioned what model of iphone do you have?
there are many iphone users on PM and if it was a phone thing i am sure there would be many threads of no iphone data.
this might help:
Early iPhone APN settings cannot be updated manually. You will need to connect to wifi, access http://www.unlockit.co.nz/mobilesettings/ with Safari, then follow the directions there. pasted from @Luddite's quirks thread
01-07-2018 05:34 AM
@Algaede You’ve posted to quite an old thread. I’ve moved it to increase visibility but if you have no replies please create a new topic.
Let us know your model. I’m sure someone will be able assist you. Assuming that it’s only data that is malfunctioning. If it is all services you should confirm your phone is unlocked.
