07-20-2017 05:39 PM - edited 01-04-2022 02:23 PM
07-30-2017 02:14 AM
Thanks for the update, @romesupe4. Glad you're up and going.
07-29-2017 07:20 AM
Hello,
Thank you. Line working now.
romesupe4
07-21-2017 11:41 AM
Hi @romesupe4,
You replied to an older, solved thread that might not have much visibility, so I've moved your post to it's own thread, in te Plans & Add-ons section.
Please contact a moderator by private messaging @CS_Agent ASAP for help. It sounds like you may have had an activation error since you don't have any services. Note that you CANNOT add talk or text to a plan by using add-ons to a plan that does not include talk or text. The "talk" add-ons are actually just long-distance minutes add-ons that have to be added to a plan that includes at least province-wide talk. And there are NO domestic texting add-ons, you have to include that as part of your plan.
Please reach out to the moderators.
