Re: Activation is broken for my account
MeadowLily
I have the same problem as the OP. My activation got to step 6 and then failed using the app.
Yes, I am using the app, I tried it on Android and an iPad, both won't go past step 6.
I can sign into the community hence why I am posting and to eversafe no problem, but yet consistently the https://identity-np.cloudapps.telus.com states the email is incorrect, and I am using autofill so no fat fingering here.
I did also try clearing the cache on the app and browser and no changes.
Any help appreciated, please.
hi @MeadowLily
happy that it helps
MeadowLily
The CS Agent fixed my activation and now I am connected.
Thanks for the help @hTideGnow 😊
hi @MeadowLily
you just need to submit ticket with CS agent and they can complete the activation for you
