Re: $29 promo for 40gb at 4G
tonisage
When porting back, did you get a new PM sim card, or did you still use the old one?
RavingRaven
@tonisage
If you sign back up to Public Mobile on Amazon you can save 50% off your first 3 months.
http://www.amazon.ca/gp/redirect.html?ie=UTF8&location=https%3A%2F%2Fwww.amazon.ca%2Fstores%2Fpage%2...
Mangia
I changed from one PM plan to the $29 promo plan. It didn’t require a new sim. I went with the digital sim anyway when I purchased my new iPhone last year.
slusagm
yes, you need a new sim card to port back.  you can buy it cheaper by buying from Amazon.ca, only $5
or you can buy the PM sim card from telus or koodo stores around you
