11-27-2019 09:08 AM - edited 01-05-2022 08:09 AM
Hi,
I was wondering if the razer phone 2 is compatible with the Public network?
Here is the information i found related to the network compatibility of this phone
TechnologyGSM / CDMA / HSPA / LTE
2G bandsGSM 850 / 900 / 1800 / 1900 CDMA 800 & TD-SCDMA
3G bandsHSDPA 850 / 900 / 1700(AWS) / 1800 / 1900 / 2100
4G bandsLTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 8(900), 12(700), 13(700), 14(700), 17(700), 18(800), 19(800), 20(800), 26(850), 28(700), 29(700), 30(2300), 32(1500), 38(2600), 39(1900), 40(2300), 41(2500), 48, 66(1700/2100), 71(600)
SpeedHSPA 42.2/5.76 Mbps, LTE-A (5CA) Cat18 1200/150 Mbps
Phones
11-28-2019 06:19 AM
You can run your IMEI and what not through the public mobile website to confirm it will work.
11-27-2019 09:27 AM
It should be compatiable.
PM uses the following bands:
4G
- B4 (1700/2100 AWS 1)
- B12 (700)
- B13 (700)
3G
- B2 (1900)
- B5 (850
11-27-2019 09:27 AM
@um_hi , this phone definitely works. My son has been using one of these phones on this network for quite a while. If you are curious, these are the bands that Telus runs on.
11-27-2019 09:11 AM
@um_hi wrote:Hi,
From that source it should be fine.
