Question
Hatimelhag
I forgot my pin number how could I get it back?
1 REPLY 1
HI @Hatimelhag   Only PM Support can assist with resetting of PIN.
Please open ticket
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. start by typing :  Contact CS Agent
  2. then Click "Contact Us"
  3. then Click "Other"
  4. finally Click "Click here to submit a ticket"
