3 weeks ago
- last edited
3 weeks ago
computergeek541
$34.00 for Unlimited Canada -US wide minutes + 50GB Data at 5G Speed
Does this plan mean I can use my phone and Data when in the USA at no additional cost or require any add-ons?
3 weeks ago - last edited 3 weeks ago
As the name of the plan applies…Canada-USA. Works in both countries. Just have to connect to AT&T or T-Mobile network on your phone settings while in the USA.
3 weeks ago
Yes, it works beautifully. Make sure your data roaming is turned on though or it wont work.
we crossed the border yesterday and it worked seamlessly.
3 weeks ago
@Hank6 Yes that’s exactly what it means , it’s a true snow bird plan . Use in the US just like you were at home . Just remember to have data roaming turned on in phone settings . And set phone to 4G/LTE not 5G and connect to T mobile or AT&T . And enjoy your time away 🙂
3 weeks ago
there are 2 different $34 plans, one for Canada only and one for Canada-US. Make sure you have the correct Canada-US plan, then you can use the service in US just like in Canada, so no additional fees Just make sure you turn on data roaming on the phone and connected to T-Mobile or AT&T
3 weeks ago
yes it will work Canada to Canada, Canada to US, US to Canada and US to US, calling, texting and data. My wife was just in the US last month and it worked well using T-Mobile but also AT&T. Just make sure the $34 plan you select is the Canada/US plan as there is another $34 plan that does NOT have US but has unlimited throttled data
If your phone is not on PM's VoLTE whitelist of devices: https://www.publicmobile.ca/en/on/get-help/articles/volte then you might need to manually select T-Mobile for calling as they still have 2G service whereas AT&T does not and 3G no longer works in the US
