11-14-2016 05:14 PM - edited 01-04-2022 06:19 PM
My contacts I have listed a 1-250-xxx-xxxx now that I am with PM will I be charged long distance if I call them? They are in my home province and just wondering if I should remove the 1 infront of the number on all my contacts
11-14-2016 05:20 PM
I do have the long distance add on that is why I was asking so that it wouldn't go against those minutes! Again the community has come through thanks for the speedy replies
11-14-2016 05:16 PM
You should not be charged, no. That being said, you can't make long distance calls without a long distance plan anyway. So in essence, you wouldn't even be able to dial them.
11-14-2016 05:16 PM - edited 11-14-2016 05:16 PM
No, if they are within the same province it shouldn't make any difference if you have the 1 in front of the number or not. I believe having the 1 will suppress the long distance prompt you would hear if you didn't include it in the phone number.
